Paralel
I found this confusing:
http://www.everymac.com/systems/apple/powerbook/specs/mac_powerbook190cs_66.html
The summarized description at the beginning says "Dual Scan" for the screen, but then further down it says "Active Matrix".
As far a I'm aware, Dual Scan is passive matrix technology. If I'm right, which section is correct, the summarized description or the spec listing?
Also, I'm already aware of this page:
http://support.apple.com/kb/TA21582
and I've already discovered two errors on it previously, so I really don't consider it to be a reliable source of information.
