Powerbook 1400 query
bluekatt
no there is no way what so ever to get beyond the 64 mb ceilling with out re designing the powerbookand creating your own motherboard
good luck with that one
you can use a cf card as virtual ram which is faster then the stock hd or ide controller
Bunsen
Admin-Witchfinder-General
Yep - VM on CF is the only way. Once you have a PCMCIA (not Cardbus) CF sleeve, you only need a smallish CF card - 64MB would double your RAM for example. Format it as a Mac hard drive, then assign it to Virtual Memory.
