The chargers from the Powerbook Duo series will work also. They won't give you enough charge to both run the laptop and charge a flat battery at the same time, but you can do one or the other.
If you can't find a Powerbook charger, you can use a stereo 6.5mm jack plug - ie a large size headphone plug, also known as TRS (Tip Ring and Sleeve). You need to put a small rubber ring (also known as a "grommet" or "cable grommet") around the base of the jack so that the divisions in the plug line up properly with the connectors inside the Powerbook. And it must be a stereo plug, not mono. I don't know the correct pinout for power, sorry.
Note I haven't tried the above, it's what I've read on Applefritter and other places.
It is definitely 24 volts you want, not 9 volts. As for the amps, anything above 1.5A (1500mA) should do it. The Powerbook will only draw as many amps as it needs, so a higher amp rating is OK. Make sure it is a regulated 24 volts though.
