Ati Radeon 9000 works with OS 9.2 native and is the last model to do so.
Oddities
Early Beige G3s could not support slave drives, as these machines (generally) had Rev. 1 motherboards and Rev. A ROMs. Later Beige G3s with Rev. 2 motherboards and Rev. B or C ROMs do support slave drives. Although the inability to support slave drives under the Classic Mac OS is inherent in the Rev. A ROM, OS X has a mechanism for supplementing the ROM code and allowing the use of slave drives.
You can use the Apple System Profiler to identify which ROM version you have:
- Rev. 1: $77D.40F2
- Rev. 2: $77D.45F1
- Rev. 3: $77D.45F2
Because of its issues, we consider the Beige G3 with a Rev. 1 motherboard a
Limited Mac.
If you have an IDE hard drive larger than 8 GB, you should partition is so that the first partition is under 8 GB in size (for simplicity, we suggest 7 GB). Failure to do this could eventually result in an unbootable computer, as all system files must be within the first 8 GB of drive space. These Macs may work successfully with larger drives for a while, but once any system files goes outside of the first 8 GB of space, you’ll have nothing but problems. This applies to both Mac OS X and the Classic Mac OS.
Mac OS X
If you have a hard drive over 8 GB in size, you
must partition it or you will not be able to install Mac OS X. If you are creating the partition within OS X, it must be
smaller than 7.4 GB as reported by Disk Utility (because sometimes a GB is billion bytes and sometimes it’s 1,073,741,824 bytes); we suggest simply setting it at 7 GB to avoid having to redo the whole installation if the partition ends up bigger than specified (it happens). Mac OS X
must be completely within the first 8 GB of space on your hard drive or you
will not be able to run OS X.
You can only boot OS X from a “master” drive in the Beige G3. This applies to hard drives and CD-ROM drives. If the CD-ROM is set to slave, you will not be able to install OS X. If the hard drive is set to slave, you will not be able to boot from it.
Non-Apple upgrades and peripherals (such as unsupported USB devices, replacement drives, and third-party memory) may cause problems when installing or booting into Mac OS X, so you may need to remove them.
Be sure to read and follow Apple’s “Read Before You Install” instructions to increase the likelihood of getting OS X installed and running on the first try.
The Beige G3 is not officially supported under
OS X 10.3 Panther, but it does work with
10.2.8 Jaguar and earlier. Panther can be installed using
XPostFacto 3, although built-in video is not currently supported.
