Power Macintosh 7200 and a G3
Status
Not open for further replies.
System7
Banned
Well the 2 hate eachother. System 7.6 hangs at happy mac. With any sonnet driver.
So I am trying to install OS 8. It hangs at "checking macintosh hd."
Any help?
I would like to use system 7 with the G3.
Rodus
System 7 is compatible with the 7200 Sonnet card so try re-setting the CPU and RAM, if still no joy then try with the original CPU, if it still doesn't work then you could have a faulty card so call Sonnet on Monday.
Mac SK
Sounds like an extension conflict. Go into the extensions manager and turn off some third party extensions. Installing conflict catcher is the answer. I had to do that on a 9600.
coius
Question: Is there a L2 Cache card, and if there is, have you tried removing it?
System7
Banned
IT WORKS!!!!
It turns out my largest 2 DIMMS are incompatible.
So I only have 32mb RAM. Back to System 7!!!!
Status
