Potentional G5 conquest
Christopher
Well, one of the bigger churches in my churches network has a small recording studio for spoken word stuff and they have dual 2GHz(early 2005) G5 sitting around. I asked about and my friend who asked the head audio tech said it was "dead".
I've been my friends computer support for a while so when they say "dead" it's as simple as a messed up system file or bad OS install. So I have a little bit of hope for it.
What I want to know is, what are the known problem of early 2005 G5 towers?
zerotypeq
If you mean the watercooled G5s they would leak not just spew everywhere at once (in the cases I am familiar with anyways), but I don't think the dual g5s are water cooled. The g5 I had was a dual 2ghz iirc and it wasn't water cooled.
~Coxy
Leader, Tactical Ops Unit
Early 2005 is presumably a dual-core model and while I think the top end was water-cooled, the low end dual 2GHz was definitely standard and ought to be pretty reliable.
Probably a bad OS install, perhaps dead GPU.
Mars478
Yeah I've seen so many times people describe computers as "Dead" and they just needed a reinstall. :D
LCGuy
LC Doctor/Hot Rodder
The thing is, to most people, needing a reinstall does = dead...for Macs it might be different, but as far as PCs go I've owned quite a few machines that I've gotten for cheap or free just because they required a reinstall, most people don't know how to do it themselves and quite frankly don't want to, and with the computer shops in town charging around $80/hour its usually worth it to ditch the machine and replace it.
