Possible Conquest: MacTable
mattsoft
Been looking for one of these for a while, and one showed up locally for $100. Thought I'd offer him $80 -- decent enough deal? Thought it would look nice with some Macs on it. The Scanco MacTable!
Cory5412
Daring Pioneer of the Future
Staff member
oooh, good luck, these are real neat. If it's in good shape and everything, $80 seems like a good deal to me, but I haven't tracked the value on these things or anything.
olePigeon
The three panels on the front are interchangeable.  It's designed to fit perfectly a Macintosh II, IIci, or compact.  It also had options like a rollable LaserWriter cubby and matching filing cabinets.  It was designed by ScanCo in Denmark.
Torbar
Oh man that's cool!  Good luck
mattsoft
I ended up picking it up but it's in pretty bad shape. figured I'd rescue it from further harm.
the frame is solid, but the desk had been stored in a damp location and the melamine coated particle board has swollen a lot. gonna see if I can get replacement melamine from Home Depot and rebuild the desktop pieces. The desktop pieces are not interchangeable like I thought -- they are held to the frame with crappy hinges so they can adjust up and down, but they don't move around. I don't know if the hinges are original though, but they are needed for the desktop to be held in place. anyway, it needs lots of work and will be a fun project for sure. a little polyurethane goes a long way!
olePigeon
I also assumed they were a quick change.  I guess you have to dismantle it to move then panels around.  The one in the picture you linked to has them in the opposite direction.  Not very useful as a computer desk in that configuration. :)
