commodorejohn
Since I got my Pismo working again, I've wanted to start putting it to more use, especially in a travel context (thanks to the two battery bays - why don't more laptops have this option?) But I've discovered something aggravating: with OS 9.2.x installed, it won't come back from sleep mode. It just sits there at the blank half-tone screen indefinitely; no disk activity, no nothing. It won't respond to the three-finger salute, I have to power it off by holding down the power button.
I know it's not a hardware thing, because I tested it during the reinstall phase with 9.0, and it worked just fine. I've read about the OS9 "sleep of death" bug, but everything I've found on it has been contemporary with the release of 9.2, and I can't find if there was ever any conclusive cause/fix discovered for this. I tried Sleeper 3.5 from St. Clair Software, which is supposed to be an Energy Saver replacement, but all that seems to do is replace the actual sleep mode with a customizable set of power-management options - you can enable proper sleep, but it lets you know that that's just falling back to the default sleep functionality and won't fix a non-functional sleep mode, so no dice there :/
I'll roll back to 9.0 if I have to, to get proper sleep-mode functionality, but I'd really rather not. Is there a better way to address this?
