PB 3400c VGA out
Franklinstein
Depending on what System you're running, try checking the "PowerBook Display" or "Monitors and Sound" control panels to see if anything is available there. Also, the "Video Mirroring" or "Resolution" control strips may allow you to change the settings.
LCGuy
LC Doctor/Hot Rodder
Just one thing - remember that VGA port on the 3400 only allows mirroring - you cannot run an extended desktop on any PowerBook 3400.
Maconthemove
Read the help doc and found out that when the vga monitor is hooked up a to a monitor, a dialog box shows up in the monitor and sound panel. The powerbook is not seeing the monitor.
