Ahh, didn't think to try it with stuffit. I've never opened bin files on an old Mac before, hence my confusion. I've already got the files on my q950 using a local ftp server on my main windows desktop.What's wrong with binary files? They are easy enough to expand. BinHex, StuffIt and many others will open them for you.
Is your problem getting them onto your Q950? If you have a CD-burner on your main machine and an external SCSI CD-ROM for your Q950, then you could burn the .bin files on to a CD-ROM.
Alternatively, if you have an external USB floppy drive, copy the .bin files on to a floppy or two. You'll need the control panel PC-Exchange on your Q950 to read FAT-formatted floppies.
A NAS might work too if you have one that supports AFP.
Just need to make an edit, the floppy emu shows garbage on the third line, not the orange pc screen. Mac os can see the disk image fine, but not the card. Thoughts?Question--
Got the orangePC app working. However, I cannot get a dos boot disk to work. I have tried several methods making a boot disk, but I keep getting "non-system disk or disk error, replace and press any key when ready", so I am unsure if it is me or the card, or maybe the program? I know that when I press any key, the activity light on the floppy emu flashes.
I dont have a usb floppy drive or diskettes unfortunately. Whenever I load up any of the dos images, the screen shows a bunch of garbage on the third line. Not sure if thats normal or not.
I think this is normal for non-Mac discs. For my GEM project I've been mucking about with FAT formatted DiskCopy images (a strange beast), and that shows complete gibberish on the third line where the disc name ought to be.Just need to make an edit, the floppy emu shows garbage on the third line, not the orange pc screen
You can use the FreeDOS bootable floppy image from here: http://www.freedos.org/download/bump-- anyone got a good guide on how to make a bootable dos floppy image?
I dont think freedos will work. I do not own a CD drive for my q950, and freedos requires either a cd drive or a way to mount the iso within the mac os for it to install. I got it booted using their floppy image, but I think after it formats its looking for the cd image, and it aborts the install since its not there.You can use the FreeDOS bootable floppy image from here: http://www.freedos.org/download/
if you look at the release candidate towards the top of the page, it has a floppy only installer. FreeDOS is probably the option I'd go for, personally.freedos requires either a cd drive or a way to mount the iso within the mac os for it to install
Are you referring to the boot floppy + cd rom option..? If so, that is what I am currently using. I am trying to get it to install the contents of the floppy image onto the hard drive so I dont have to go through the installer every time the computer boots up just to back out and get to the freedos prompt. I've tried formatting the "hard drive" to be an active ms dos partition and copied the contents of the floppy image to the hard drive to see if it will boot from the drive, but the card hangs after doing the ram check, unless I load the freedos floppy image.if you look at the release candidate towards the top of the page, it has a floppy only installer. FreeDOS is probably the option I'd go for, personally.
Alternatively if you want to be more period-correct (but legally questionable, which may also be period-correct depending on how disreputable one's friends were at that period, I suppose), there are loads of abandonware places that you can get MS-DOS from. If you want the eccentric option, I probably still have OpenDOS discs somewhere If the card boots OK off the FreeDOS boot disc, to the point of trying to install off the CD, probably about any DOS boot disc out there will work.
No: go here http://www.ibiblio.org/pub/micro/pc-stuff/freedos/files/distributions/1.3/previews/1.3-rc3/ and download FD13-x86.zip. This contains six floppy disc images which you can install from.Are you referring to the boot floppy + cd rom option
Bad news--tried the x86-BOOT image, and the floppyemu says its an unsupported image typeNo: go here http://www.ibiblio.org/pub/micro/pc-stuff/freedos/files/distributions/1.3/previews/1.3-rc3/ and download FD13-x86.zip. This contains six floppy disc images which you can install from.
