Ooh, what is this?
Quadraman
There were a handful of external monitor adapters for the SE but they were nothing like the ones made for the SE/30. One was by Radius for use with their portrait monitor. There was another one that was 1-bit external video. and I think one or two others. None of them really upped the resolution or accelerated the video, just moved it to a larger screen and none of them are compatible with any other upgrades so no CPU upgrades or ethernet adapters in your SE if you need an external monitor. Since there is no boost in resolution or acceleration that makes the value of an external adapter questionable in an SE. A faster CPU or ethernet adapter would be more valuable in most cases and I would lean towards an ethernet adapter as being the most valuable upgrade you could put in the expansion slot of an SE.
