Ooh, what is this?
Gil
I opened my SE 4MB dual 800k today for the first time. I'm still terrified of CRT's, so I could not touch anything. However, I noticed that there is a DE-9 port in the expansion port, though the expansion cover on the back case was covering it. There is a wire going from this port, to a card in the PDS slot.
What is it?
Bunsen
Admin-Witchfinder-General
There were a number of display adapters available for the SE. It could be Lapis, Radius (inc Pivot) or a few other manufacturers. If you can pull the PDS card and look for identifying marks, that will help.
If it's truly a PDS card and not something that jumpers on to the internal video signals, you have a better than average chance of hooking this up to an external monitor of some kind.
But please - don't go plugging anything into it until you know for sure what it is, and what it's capable of.
http://www.lowendmac.com/video/68k/index.html
Osgeld
Banned
I have a ttl monitor (well really old multisync, ttl to vga level rgb, anyone want the beast?) and they do indeed use the 9 pin, but so does RGB ect
Gil
I would take out the card, but would that involve discharging the CRT? This is my first compact, so I'm not familiar with the inner workings yet, and quite frankly I'm scared to death. :-/
iMac600
You're pretty safe, if you want to be really cautious then just avoid touching the CRT while removing the card. The charge in the tube isn't distributed through the logic board or that card, just the analog board and the CRT.
That said i'm pretty sure the Macintosh SE has bleeder circuitry to discharge the tube on shutdown anyway, the last few times I discharged my SE CRT it didn't have any charge in it at all despite the fact it had only been running a few minutes earlier. It must have that circuitry on the analog board or in the flyback transformer (entirely possible, as the flyback is a later revision from the 128k, 512k & Plus, despite the fact the CRTs are the same).
Bunsen
I have vague memories of Cornerstone having something to do with high end fixed frequency monitors back in the old days.
With all those RAM chips on board, IMHO it's definitely a bona fide video card and not just a simple TTL converter. What kind of video it outputs is a whole other question, and the chances of it being VGA are next to nil.
Bunsen
No, you spelled "propitiatory" correctly. The word you're looking for is "proprietary".
And yes, it probably is.
