Several Outbound Model 125 Laptops (Laptop, not the more common Notebook) with external floppy drive and SCSI adapters. Spare parts and most of the components I need to clone the external floppy drive. I still need an affordable supply of WD92C32 chips. When sold, these laptops are usually separated from their external floppy, and they have no internal floppy, making software installation, especially OS re-loading problematical.
Daystar adapter to put PowerCache or Turbo040 in Macs with an LC-style PDS slot.
Daystar adapter to put PowerCache or Turbo040 in a Mac IIcx. I hope to some day clone this thing so that it will physically fit in an SE/30. It should already be electrically compatible.
Video Vision Telecast system, but I've never actually used it. I'm a bit embarrassed by that.
Ten sets of four 16MB SIMMs for the IIfx sitting on my desk waiting to be assembled (chips and boards).
Several Power Computing Power 80/100/120 machines--the 8100 clone. These have spots for 5 NuBus slots on the motherboard, but one would need to steal the Fat-AMIC chip from a 9150 to implement the two uninstalled slots. I will probably never get around to this project.
Applied Engineering FDHD+, IIRC. I know I have the drive, just not sure if I correctly remember the name. The one that let's you use a 1.44 MB floppy on the Plus.
Three HD20 hard drives. The 20 MB Apple drive that connects by the floppy port.
Newlife Upgrade which installs in a Mac 128KE or 512KE and provides SCSI and 8 SIMM slots. That's right, 8 SIMM slots. In a Mac 512KE, one could install two 1MB SIMMs and six inexpensive 256K SIMMs and get a total of 4 MB (512K on motherboard). Back then it was a significant savings, since 1 MB SIMMs were upwards of $100 each.
Lapis Display Server Plus, external video upgrade for the Mac Plus. Clips over the CPU and actually provides a second display.
5 Brainstorm accelerators.
Microspot MacPalette II software, this is a print driver (extension) for the ImageWriter II which causes it to dither using the four color ribbon such that it can print in millions of colors. The output is surprisingly good, given that it's coming from a 72/144 dpi output device.
