LaPorta
Now that my Portable is done, next on my list is my 512k. I got this little guy around 2000/2001 on eBay when I was in high school for $5 (about the going rate then). It worked, but the front upper corners of the front bezel were cracked off (I epoxied these then). I haven’t started it up for about 14 years or so. At that time, it exhibited symptoms of bad solder joints (screen off; banging on the left side brought the screen on). That will be easy to rectify.
A re-cap is in order, of course. Other than that, there’s a few questions I have.
Is there anywhere, other than a donor analog board, that I can get the same style battery holder? The negative side holding hinge broke off.
Is there somewhere to get equivalent square, double-sided adhesive sponge that holds on the plastic sheet on the side of the analog board? I like to keep things original.
