My apologies in advance, this post is going to be a little poorly structured because I jumped around while writing it and I'm on a morning time crunch to leave the house and go to work:
The whole concept of the original post is smug. It presumes you have the skills, time, equipment, and wherewithal to build the Tiny SCSI Emulator. (And that somehow for those reasons alone, it's better than the SCSI2SD.)
I think there are plenty of situations where that's not worthwhile. People for whom it's literally less expensive to buy a SCSI2SD than buy start-up materials, spend some time learning, and then build a TSE.
Hell, for some people, it's not even a money thing. Between my chronic illness and my job, I don't really have the physical wherewithal or the motivation to "do things" in my off time. I'm not living a particularly lavish lifestyle (in my 1200sf with my new housemate). But I can set aside a little bit of money to build a "send off to be recapped" fund (since that is acknowledged the most common needed repair for '90s modular Macs, which is what I have) and to save for a scsi2sd and perhaps a floppyemu. These aren't things I "need" and I can make do without them (my systems have fortunately been very well cared for their entire lives), and yes, it's physically possible for me to learn soldering and build a TSE or recap my Macs, but that's not why I came here fifteen years ago (actually it might be sixteen now) and it's not something I personally find fun.
And yes, troubleshooting is a different skill, I literally do tech support for a living, so I'm aware of that. But how frequent are hardware failures here? Especially board-level troubleshooting? Something like 90% of the troubleshooting (dead PSU, floppy disk drive needs maintenance or replacement, hard disk needs maintenance, PRAM battery is dead) that occurs here is both stuff that we did fifteen years ago, before to my knowledge literally anybody had recapped any Macs, and is all stuff that's covered in the manuals that came with these old machines.
So I don't think it's smug to say that I don't think everybody should have to learn soldering to do recaps or build simple peripherals in order to even be here on this site, and I don't think it's smug to suggest that in a friendly community with a peer-to-peer marketplace, the people who do can't both give back and earn an extra few dollars. I think that as a site, we should be able to accomodate and maybe even encourage as normal and reasonable both ways, and assist people moving from one situation to another.
But that's not the tone I see so often. The tone I see so often is that if you're not a pro at soldering you shouldn't bother with vintage computers at all, and I consider that to be a shame, because that attitude makes people who are less physically or technically inclined miss out on a lot of fun and history and productivity. That's not new though, and it's not something that'll change overnight. It is something we can talk about and frame in a way that hopefully incentivizes us to try to make it easier for newcomers.
I could not agree with you any more. Just because one does not have racing skills when we get behind the wheel and drive our cars does not make us bad drivers, even professional drivers as in cab/taxi, trucks and emergency services driving.
People do not need to know how to solder to diagnose their machines. They can figure out what is wrong with it and then if it needs soldering, get someone to do the job for you. At least you know what needs to be done.
I'm not the "best" or "most informed" member of the forum but I know what I know through experience and learn everyday something new. So let me state A bit of off-topicness which does connect to this discussion.
2015 I bought a couple of Raspberry Pi Model Bs from ebay because the sellers said that they were broken. I spent like $5 for each of them. 2 of them (from the same seller) had crushed ports and shorted out ports. I asked to what happened to do this but the seller would not budge in giving me the story. The other the seller admits to sending 12V into the GPIO to power up the .Raspberry Pi for some robotics project and believes that he fried it to death. A Fourth one had its SD Card holder broken and could not hold the SD card in place. The Seller says that somebody tripped over its power cable and sent the unit flying until it crashed into a wall. He did add that it does boot from the SD Card if you use a tiny wood clamp t hold the SD card in place in the broken SD Card Slot.
I diagnosed the problem with the 3 R-Pi's; with the one with the crushed ports had their pins shorting against the case. Cutting the wires to eliminate the short fixed it, but it now has no ports. The one with the broken SD Card holder worked as he describe with a tiny wood clamp holding the SD card in place. The fried one was tricky. It did boot up if one used a 5V 2A power adapter, but checking the voltages they were found to be off the scale. The 5V line was all over the place from 4.1V to 6V and was not steady. The 3.3 line read zero. I looked them over with a magnifying glass and found 3.3V regulator to be cracked, and the 5V regulator to have a bulge in it.
Luck for me I can solder. Because I submitted these findings to the R-Pi forum and I was basically told by everyone (including the admins) to throw them away and buy new ones. For me the hard part was finding the parts. Mouser had the regulators, and I found the SD Card Slot Holder, compatible USB Ports and a compatible Ethernet port for the RPi's on ebay, though they were not cheap.
It took a long time, because they used a high temp non-Lead solder which was difficult to remove. But in replacing the broken parts, I got 4 working R-Pis that the original owners considered as dead. Funny - the one with the replaced ports, that model uses Black USB Ports, and I used White UBS Ports, making these two the only R-Pis of this model to have White Ports! Similarly, the broken SD Card was replaced too and it too works like it should. The hardest was the regulars replacement, as those are some damn tiny connections! But now it can now boot up and run with a 5V 1.5A power adapter and the voltages are rock steady!
Then I reported back to the R-Pi and posted up my repairs. I dd not believe that many were bothered and even angered that someone would take their time to fix a broken R-Pi. Even the Admins stated, 'This is great that you fixed them but we do not recommend anyone into fixing their R-Pi's. They are cheap enough for one to buy a new one in case they accidentally kill their old one." There were a few members that were ecstatic in what I did but the majority of the group was totally against it. (WHY?!!)
What does this have to do with Macs? Like you stated, one does not need to know how to solder to fix their machines. But if they diagnose their machines that it does need some solder work on it, they are ahead of the game in knowing what needs to be done and send it out to get that part done for them. You can even buy the replacement parts that needs to be soldered and send out the board with the parts. Soldering is a nice skill to have but it is not a life & death skill to have.
