My LC III wants to be a DJ.
Lateralus
When powered on, my LC III intermittently emits whining noises in varying tones through its speaker. I've swapped the speaker to no avail.
The kicker is that if I touch miscellaneous chips on the motherboard with varying degrees of pressure, I can alter the pitch and repetition rate of the whine.
Why is my LC III a beat machine?
porter
Beats me!
My LC II and III both make whining noises which I assume are coming from the PSU which subside after a few minutes, I assume that they are merely going supersonic rather than actually abating.
Lateralus
You might wanna check. I assumed mine was the PSU as well, but it's definitely the speaker.
Once on, it goes quit every now and then only to start the whine again a few seconds later. Definitely not something that being powered on for a while cures.
porter
Could be noise on the power rails then. Do you have a similar machine you can swap components with to eliminate them from your inquiry? Eg swap PSU etc.
Dennis Nedry
Most likely it's bad capacitors on the logic board.
I have one that does this too from the speaker. It sounds like an old AM radio.
Lateralus
The board looks perfect, top and bottom. So I don't know.
Maybe my IIci spread a disease to it while they were in the closet together this past year...
Regardless, I'm more willing to screw with the LC III to keep it viable than I am the IIci. The LC III, majestically sitting next to a garbage can as I passed by on the walk home from school one day, won my heart and brought me over from the dark side.
FakeWozniak
New member
I just got an LCIII from ebay and it has that whine/hiss/am radio noise too.
From my hardware background, I would think it was a failed capacitor too. I've noticed that while it oscillates audibly, the actual sounds going over the speaker (Apple Menu -> Control Panel -> Sounds, then clicking an alert sound like Quack) will be garbled. I would suspect the problem is isolated to the audio driver. Maybe something like a 555 Op Amp or a supporting capacitor.
Anyone isolate this further? If so, please post! I will post what I find.
indibil
I know it's been a long time since this post, but I have an LC3 with the same noises. I have changed capacitors of the supply and of the motherboard, and they are still there.
Has anyone figured out what causes these noises?
Thank you.
mikes-macs
It’s a mystery to me. I have never heard of this problem before now. It was usually the Mac IIsi that had all of the sound problems. I’ve got a Performa 400 with no sound issues at all. Perhaps you got some device in your home that causes interference.
Daniël
I'd guess the DFAC (digitally filtered audio chip) would be at fault. They tend to die from cap leakage, and can do weird things when damaged/dying like noisy sound, intermittent sound, extremely weak signals, etc.
indibil
I also had oscillation after recapping.
Changing C4 to 47uF solved it for me.
Thank you so much! I have replaced the new 10uF C4 with another 47uF one and the noise is gone!!!!
It can't be the fault of anything in my house because I have another LCIII that doesn't have that problem, with the factory capacitors.
