slomacuser was so kind to send that card to me:
I popped it into my Q950 and threw various drivers at it to see what happens.
The Prisma16 driver floating around the web does nothing.
I could source a few more drivers from the guy who is running
http://www.mirosupport.de (Thanks Maik
He had drivers for the Chroma, Chroma1152GT, Prisma2, Prisma1152GX and the control panels for various CRTs miro made.
All those did not do anything for my card though besides the miroDESKTOP control panel would allow me to change color depth using shortcuts just like the Radius desktop CP (the CP looks to be exactly the same besides it has all Radius references replaced with miro - I have another miro Nubus card which is a rebranded Radius card so this would make some sense at least)
I checked my own archive for everything miro related and could actually find Monitors CP extensions for the card. Why didn't I check my own stuff at first? :evil:
The extension enables some additional options in the Monitors CP:
A bit hard to read but the card can go up to 1408x1024 and I would guess it does that at 24bit color as well.
Notice the TV option on the left. So one of the additional ports must indeed an S-Video port to output video to a TV. I will have to test this later on.
The second port that looks like S-Video is a serial port. Some miro CRTs had serial ports to be controlled by the control panels I mentioned above.
In the control panel you could choose where your CRT is connected:
You could also connect the monitor to the modem or printer port but could as well use the one on the graphics card.
As I do not have a miro CRT I can not go any further from there.
I benchmarked the card against my Q950s built in video and it comes out nearly the same. Speedometer 4.02 QuickDraw benchmark at 16bit color comes in with a 1.226 for the miro card and 1.270 for the onboard video. (a Thunder IV scores 0.538 at that test according to the old benchmarks at LEM, now how does that sound? :evil: )
So the card has acceleration built into its driver in the ROM as none of the above miroACCEL CPs were installed when running the benchmark (they did not load anyways even when installed as they just were not the correct ones for the RainbowGX)
With one of the ports being S-Video output and the other one being a serial port this card also can not do video capture. It is pretty damn nice to connect a second screen which will be nearly as fast as the onboard video. You can't do that with Nubus cards.
