Manual load internal floppy drive in Quadra 700?
LazarusNine
I need to replace the internal floppy drive in my recently acquired Quadra 700. Given my lack of success sourcing an auto-loading floppy drive, I'm wondering if it's possible and/or useable to replace the drive with one of the newer manual drives. I wouldn't imagine ejecting a disk would be a problem, but perhaps insertion is a bit more difficult? Anyone with any experience with this or advice? Many thanks!
bibilit
Will work, but you will be in trouble ejecting disks, as nothing is provided (IIRC) to do so in the Q700.
uniserver
call up ted hodges, he has a pile of those auto injects…  usps first class international is pretty cheap.
MJ313
I just read your post on another site-- take the guy's suggestions to clean and lubricate the drive and I bet it works fine.
Get yourself some isopropyl alcohol, white lithium grease and some q-tips and follow the directions here:
https://wiki.68kmla.org/Floppy_Drive_Lubrication
unity
White lithium can be evil when it dries up. I use 4in1 oil. Holds up fine, easy to clean and rejuvenate years later.
LazarusNine
Alas, it seems the floppy drive mechanism is most definitely kaput. Thank you all for your suggestions. I gave it a full clean using some of the directed techniques, and reapplied grease to no avail. The drive continues operating poorly. I'll look into contacting Ted Hodges once I can find out his contact info. Many thanks once again!
