It is, and to be honest, this is unrelated, but I'm thinking of asking my telco to give it to me, for hilarity reasons. I've got a small PBX I can pipe a BRI or a PRI into and get some neat calling functionality with.
Anyway, the trouble would be, ISDN might not be something the telco has a lot of capacity for, might require line conditioning (though probably not more than DSL), etc.
Please do! And thanks.I might have an original 300Mhz card kicking around here somewhere...... I'd have to look.
Hey thanks for looking!No dice on finding the card. It must have went with the 8600 when it was disposed of.
If I had a 5.25" cutout faceplate and didn't need a CDR in there I would install a MO drive or some kind of tape drive for backups.Debating and need your opinions----should i even bother to put another CD-R drive in this machine?
I have been burning CD's on my mac USB superdrive via IMGBurn on a Win 10 PC. So i don't NEED to have a CDR/Toast running on here.
Would you bother? Or just skip it; toss the dead unit, and cover it up with a blank cover piece to return to the stock look.
I've always had pretty good experience with Toast Titanium 5.1, which I think is the last version to support Classic Mac OS.If you already have a solution, I would use it. If I need discs, I use my iMac G4 to burn them. I always found OS 9 burning unreliable (just my experience), and using 10.4 with the iMac has given me a better experience.
