I guess this is as good a place as any:
I unpacked and gibletized one of these today:
NEW 10" SVGA Color CRT - $40 [$16 + $24 S&H]
. . . never even tested it, I'll do that after it's safely installed in a different hack, but trying it out where the MIA CRT used to reside seemed like the thing to do:
This unit is shorter front to back and the PCB is far smaller, but the older one had better suited curvature than the new one, IIRC. It's very nice that the controls are on a separate board, so they can be relocated with ease. Strapping a modem case onto the back of the Classic would hide the CRT Neck/Board very nicely, that, or maybe a faked up HDD case. The board sits too high up the back of the Classis to try a BackPackHack, the angles are still all wrong.
Here you can see how little sticks out the back . . .
edit: I have to take another shot of this, I tried to keep the lens centered across the backplane of the Classic, but it's too far forward. More sticks out the back than meets the eye here. This shot makes it look like the angle of the chamfer plane leads to the top edge of the deflection board, it doesn't. I'll take a better pic.
. . . the curvature leaves something to be desired . . . likely due to the shorter overall length . . . TANSTAFL . . .
. . . there's just room enough to put a PowerBook SlotLoader behind the CD Slot underneath the PCB if it's mounted as closely to the neck assemby as possible . . .
. . . I didn't trim back the ears on this one, but they don't stick as far out as the original CRT, note the slots cut in the bucket that hold the CRT in place . . .
. . . also note the nasty bow at the top edge of the bucket . . . I
just barely got the bucket snugged up to the front bezel for the first two shots . . .
. . . low/back oblique of the monitor's giblets . . .
. . . @$$ end view . . .
. . . @$$less view . . .
This monitor is a very nice little package. What's
really nice about this one for a Classic Hack is that the curvature of the front bezel of the monitor is dead on with that of the Classic. There are even lines around the opening to use as a guide in making an even cut around the edge. Splicing the monitor's CRT Surround into the Classic's front bezel would yield a perfect fit and move the CRT & its @$$ end a significant, if not entirely effective, distance forward into the bucket . . .
. . . and it would look nice as hell from the front after painting the spliced together bezels. }
