Apple changed the design before the SE/30 was released. If you knew that you were going to sell an upgrade that wouldn't fit, wouldn't you try to get the change into the production process as quickly as possible? Uniserver's photos show a pre-FDHD SE which had a brief overlap with the SE/30.That's strange, did they standardize on the vertical slot opening after the release of the SE/30?
I figured Radius had a part in getting that vertical slot into the spec if it hadn't been there, heck, Aldus probably got on them to allow for more expansion. :Apple changed the design before the SE/30 was released.
Yeah, Apple changed the serial number coding on the 1990-91 Macs. Throws the serial decoder for a loop. Checked mine as well, and it did the same thing. Emailed the guy who runs the site, and he menitoned that.F83401XM5010Well I guess my SE a slightly newer then what I thought.
Manufactured in: F => Fremont, California, USA
Year of production: 1988
Week of production: 34
Production number: 01X => 65
Modell ID: M5010 => Macintosh SE(shipped with 2 floppy drives)
Your Macintosh SE(shipped with 2 floppy drives) was the 65th Mac manufactured during the 34th week of 1988 in Fremont, California, USA.
Here I will check my FDHD: it says 1988 right on the label.
F10152MNB03
well this makes no sense:
Year of production: 1981
Week of production: 1
Production number: 52M => 5869
Modell ID: NB03 => unknown Mac
Your unknown Mac was the 5869th Mac manufactured during the 1st week of 1981 in Fremont, California, USA.
