Macintosh SE HD Activity Light Hookup
Benno
Hi
Is it possible to hook up the Mac SE Hard drive activity light to a different HD. I want to install the Mac 40SC HD in my SE and was wondering if any of the pins pictured on the en d of the HD would run the activity LED on the front of the Mac.
If not is there a way to hook up LED ?
Thanks
Ben
marcelv
Code:
                      J   U   M   P   E   R   S
CONNER   CP3040  PRODUCT MANUAL 00501-016
 Jumper setting
 J2  SCSI Connector Pin Assignments
          | Signal     |Pin No. |   Signal    |Pin No.|
          | -DB(0)     |   2    |   -DB(1)    |   4   |
          | -DB(2)     |   6    |   -DB(3)    |   8   |
          | -DB(4)     |  10    |   -DB(5)    |  12   |
          | -DB(6)     |  14    |   -DB(7)    |  16   |
          | -DB(P)     |  18    |   GROUND    |  20   |
          | GROUND     |  22    |   GROUND    |  24   |
          | TRMPWR     |  26    |   GROUND    |  28   |
          | GROUND     |  30    |   -ATN      |  32   |
          | GROUND     |  34    |   -BSY      |  36   |
          | -ACK       |  38    |   -RST      |  40   |
          | -MSG       |  42    |   -SEL      |  44   |
          | -C/D       |  46    |   -REQ      |  48   |
          | -I/O       |  50    |             |       |
          The minus sign (-) indicates active low.
          All odd pins except pin 25 must be connected to ground.
          Pin 25 is left open.
 SCSI ID Jumpers
  | Drive Select |   E1     |  E2    |  E3    |  E4/P |
  |     0        |  OPEN    | OPEN   | OPEN   |   -   |
  |     1        |  CLOSED  | OPEN   | OPEN   |   -   |
  |     2        |  OPEN    | CLOSED | OPEN   |   -   |
  |     3        |  CLOSED  | CLOSED | OPEN   |   -   |
  |     4        |  OPEN    | OPEN   | CLOSED |   -   |
  |     5        |  CLOSED  | OPEN   | CLOSED |   -   |
  |     6        |  OPEN    | CLOSED | CLOSED |   -   |
  |     7        |  CLOSED  | CLOSED | CLOSED |   -   |
  There are four jumpers available for configuration. Three of these
  jumpers, E1, E2, and E3, are used to select the drive's SCSI ID,
  installing E4 disables parity.
 E4  Parity Jumper
 E4     OPEN     Parity check enabled
        CLOSED   Parity check disabled
 J4  LED DRIVE CAPABILITY
 1. 14-Pin Auxiliary Connector
    Pins 1 & 2 of the SERIAL IN/OUT connector may be used for an ex-
    ternal LED.
 2. 16-Pin Auxiliary Connector
    Pins 3 & 4 of the SERIAL IN/OUT connector may be used for an ex-
    ternal LED.
 3. Separate LED-Connector
    The newest drive-versions have a separate (white) LED-Connector
 J3  Power
      | 1 2 3 4 |
        | | | +----------- + 5V
        | | +------------- GND
        | +--------------- GND
        +----------------- + 12V
Benno
Confirming the pointed to pins in the diagram works for the SC40 HD drive.
