I don't know the specific card, but have you tried the Mobius drivers here :Hi to all,
Six Years ago i posted if someone had the init and control panel for a mobius speedscreen se, i never found those driver, maybe in six years someone had a better luck and can help me.
Thanks in advance and best Regards.
Vincent.
Yes, they are for the mobius 030 accelerator, the speedscreen se it's a 68k 16 mhz accelerator with a full page dysplay output.I don't know the specific card, but have you tried the Mobius drivers here :
Have you tried the Mobius Video driver from there? I thought were drivers for multiple Mobius cards there, must be thinking of something else.Yes, they are for the mobius 030 accelerator, the speedscreen se it's a 68k 16 mhz accelerator with a full page dysplay output.
Ok i give it a try.Have you tried the Mobius Video driver from there? I thought were drivers for multiple Mobius cards there, must be thinking odlf something else.
I'd suggest trying the GemStart driver for the processor bit, they work with some Mobius upgrades.
What System Software version are you running?Ok i give it a try.
Thanks
system 6.0.8What System Software version are you running?
no luck with the gemstart initsystem 6.0.8
What happens, because most SE accelerators sort of work even without drivers?no luck with the gemstart init
I used tattletech to analise but didn't found anything about the hardware, but when i installed ramdoubler, the software alert to me that he can't start the ramdoubler because of an accelerator installed.What happens, because most SE accelerators sort of work even without drivers?
I don't understand what you're saying. TattleTech tells you what processor is being used on the tab that opens on launch.I used tattletech to analise but didn't found anything about the hardware, but when i installed ramdoubler, the software alert to me that he can't start the ramdoubler because of an accelerator installed.
Yes exactly tuttletech said that i'm using a 68000 8 mhz processor did'nt mention 68000 16 mhz processorI don't understand what you're saying. TattleTech tells you what processor is being used on the tab that opens on launch.
there is a disgnostic tooll that can find the hardware of the accelerator board?Yes exactly tuttletech said that i'm using a 68000 8 mhz processor did'nt mention 68000 16 mhz processor
Ah sorry, I forgot you were running System 6. Try this :thanks i'll doing but wait norton 3.1.3 ifor system 7 i had system 6.0.8, maybe system info works under system 6
So the video control panel that comes with the Mobius drivers didn't work? I have the Mobius 030 in my SE with video out and it is working with the drivers from https://vintageapple.org/macdrivers/accel.shtml.Ok i give it a try.
Thanks
Hi and thanks,So the video control panel that comes with the Mobius drivers didn't work? I have the Mobius 030 in my SE with video out and it is working with the drivers from https://vintageapple.org/macdrivers/accel.shtml.
Weird, I can't find advertisements for this card, usually when I search the internet archive I can find something, but no hits so far. What I did find in mention of something just called "the mobius card", which sounds like it may be the same card, or it's predecessor.
I just posted a bunch of drivers for the NewLife cards on my site, they also have video output. I doubt they'd work but it's worth a try.
