BacioiuC
Hi everyone,
Yesterday I've installed a Total Systems Mercury accelerator in my Macintosh SE. Been playing and working on it on and off through the entire day yesterday without any issues and went through a couple of power cycles. Worked without any issues.
Today I've booted up the Mac and it initially told me that "it doesn't have enough memory to load all the extensions". I disabled all extensions, to figure out which was causing an issue and it booted into a "Sorry, a system error occurred. "Finder" error type 41 ". Note that it has 4 MB of ram and it ran perfectly until now.
I've turned off all extensions (from the Extension Manager) and this issue still occurs. I can restart the Mac with the shift key pressed and it boots into System 7.5.3.
With "extensions off" via the shift key, when I start extension manager from the Control Panel I receive an error saying "An Error -127 occurred while getting the information on the following file: EM Extension".
Any idea what the cause might be?
Edit: note, I want to try out a few things before removing the accelerator. Nothing new was installed (except gemstart 3) since putting in the accelerator and it worked through quite a few power-cycles yesterday.
