techgeek
Hi guys! I need help with a Macintosh LC 475 that I've been trying to revive for quite some time. It had a badly corroded battery which I removed and cleaned up the rust - no traces or anything else on the motherboard has been damaged except for two capacitors which have since been replaced. This is not the first motherboard I have worked on, so I am sure that the remaining capacitors are OK. The power cycling does the trick, but after the LC chimes nothing shows up on my Apple CRT monitor. However, if I connect one of my LCD monitors it detects a signal, but what I find very strange are the H and V frequencies (see the pictures below). The horizontal frequency is 91.7KHz and the vertical one is 113Hz. Does anyone have any idea what could be causing that? I have never seen any such behavior before. Any ideas would be greatly appreciated.
