Hello all. Avid readers may recall I recently repaired an SE FDHD. Along the way, I noticed some infrequent, momentary narrowing of the CRT image, so I recapped the analog board. It seemed to be fixed so I reassembled the case and declared victory. But last night the screen had a period where it was less stable than before.
I've spent part of today combing through the Compact Mac category of posts here, but with over two hundred pages of topics left to go, thought I'd ask here. If there's already a topic all about this - just point me at it, please!
TIA
First step will be, of course, to go in and review my work. I did a careful review before I applied the hot-glue and found one mistake, which I fixed. Perhaps I missed something else.
While I'm on that, anyone care to suggest the next most likely repair to try? I have not recapped the logic board, nor the PSU. I replaced no transistors. I will dust off my analog oscilloscope to check the voltages + jitter at the floppy port later today.
One question I have is that this SE FDHD came with two internal 1440K floppies and an internal HDD. I am uncertain whether or not this was a supported configuration, and I wonder if I am sagging the PSU (I also added more RAM), and if that might lead to this type of screen issue? Could I be underdriving the horizontal deflection coil?
More details below. Thanks for reading this, and regards.
-A
Details: The original system pre-repair was in good shape, just a dead PRAM battery (not exploded), noisy fan, and a failed HDD. The screen now behaves very well, sometimes for prolonged periods. When it jitters, it now tends to jitter for many seconds in a row, then let up. I'm not sure, but it may be a sign of a temperature intermittent, or charge build-up somewhere that manages to drain but then builds back up after a while. Possibly I didn't get a good solder contact on one side of a replaced cap. I do not know. I'm not a skilled electrical engineer...
-A
