Impressive! I wish I had one of those. But the only auctions I've seen of a MicroTouch are the ones you won I think. I wonder how difficult it would be to replicate one with a modern film. Hummmm...
It is an internal interface board that converts the capacitive glass plate touchscreen to ADB. This is the board inside that is stuck to the power supply with stand-offs and two-sided tape. It takes power from the motherboard connector. The 9 pin D-sub connector is from the touchscreen and below it is the ADB output port. You connect that ADB port to the external ADB port.
Here is the touchscreen attached with two-sided tape to the CRT. There is a bit of a gap.
