Mac Plus force SCSI ID for boot
SDUBjed
I want to force my Mac Plus to boot from a certain SCSI ID, where I have a chain that has multiple drives that contain system folders.
I can't change the SCSI IDs of the drives due to other circumstances, so I want to force the Mac Plus to boot from a certain ID.  As it is now, the Mac keeps booting from the wrong drive (the one with the larger ID #).
Can I make a boot floppy that will tell the Plus to boot from a certain SCSI ID?
Thanks!
SDUBjed
The "Startup Disk" app is not compatible with the Mac Plus.  I have confirmed this to be true, and read it online, but I don't know exactly why it's true.
Thank you.
BadGoldEagle
I don’t remember if system picker can detect system folders on multiple partitions/hard drives...
Try it out though, it might solve your problem.
Dog Cow
"The "Startup Device" cdev is only supported on the SE and up, which have the additional firmware to support it. The Plus will boot the SCSI device with the highest ID number, so if you want to change the boot order, just change the SCSI ID." Source: Mac Plus Startup Device.
