well, the Quadra 660av finally showed up. Horrible packing job by seller broken plastic everywhere the HD caddy the floppy drive-the entire "tray" that is underneath the floppy cd and HDD that is loose as well. I saw pictures of the inside before it was shipped and the HDD was properly in its spot. and when I opened it it was laying on top of the CPU... so it was bouncing around like a pinball the whole time it was being shipped!
so beyond that couple of things
I replaced the non-leaking PRAM battery (said made in 96) with a new one I wasn't getting video signal before
I was having a hard time getting my NEC 40X scsi to boot from CDs..turns out the quadra has no clue of "C" key. its option apple shift and delete. that worked
it did still somehow still manage to boot system 7.5.1 off the internal original 250MB HD. it sounds like bearing death but it was booting.
notice I said WAS that's because I wanted to initialize it using my 7.5.3 CD and reinstall well the initialization failed. and I have no hdd now.
I should go straight to SCSI2SD now, huh unless somebody has a 50-pin SCSI hardrive haha. I tried test using the HD SC tool and that fails too. tried restarting power cycle nothing works it runs for a bit and then it fails with "this disk could not be initialized"
