makkuss2000
Hello to everyone, after recapped my Mac Classic (Analogic Board and Logic Board), everything was working really good but after 10 minutes i got an Horizontal line (picture1)
Before this thing happend, i heared a strange and little noise came from analogic board like a buzz but i didn't gave importance (i thought was normal) but after 10 minutes i got an Horizontal line (picture 1).
I started to chech what it could be and i found that on PIN 16 (power supply) of my TEA2037 i didn't have the 9.8V necessary to let start the vertical section.
I checked for a bad cap or transistor and i discovered tha the cap CF2 was gone (it's near the power of TEA2037).
After change it, the Vertical IC start to work but now i have this situation showed in the picture 2.
I checked everything (caps and resistor) and i controlled also the wave by oscilloscope on BD1 (YOKE PLUG) and i have this result:
PIN 1 : 22.5Khz wave (good)
PIN 2 : ground
PIN 3 : on this i don't have as showed in the sheet instruction the right frequency (i got 3/5 hz pulsing instead of 60.15 Hz stable) - picture 3
PIN 4 : 60.15 Hz wave (good)
I tried to change the TEA2037 but nothing, always the same result....
So i just ask for some HELP because i don't know what it could be.
PIN 2 : ground
