Elfen
Interesting. If it were an SE/30, it would be a RAM or broken trace issue. But since this is intermittent.... Hmmm... Page 65 of Dead Mac Scrolls says its a ROM Issue, probably after an upgrade.
Take out the board and with a chip remover or pencil and small flat head screw driver, loosen the ROMs and IWM chips (next to the ROM, if it is in a socket), wiggle them on the sockets and gently press them back in.
If it continues, then there is corrosion on the chips' pins. Remove the ROMs one and a time and with very fine Emory cloth, not Sandpaper - ask your hardware store for Emory Cloth, they know what it is, polish up the pins on the chips on both sides - the outside of the chip and the inside. Be gentle doing this so you don't bend a pin(s). Put ROM back in socket and do the other ROM and then the IWM Chip last.
After many years, sometimes the connections corrode over time and need to be cleaned up.
