yup i think i still have like 800 4164's -samsung.
i find that apple logo'd ram is the worst.
you should change them all.
i personally don't like sockets and don't see a need for them.
Once you change all the ram with some high quality samsung ram or equivalent,
the need to change ram in there will be something of the past.
The stuff apple threw in there was crap.
I also don't like upgraded 128k's, if you want 512k ram.. then get a 512k.
( but that is just me ) its your puter, its much more collectable stock.
especially an original Macintosh Mobo like that one.
Also, just adding higher density ram to a 128k, upgrading it to a 512k is not just a Drop in solution… You need a mux and some other parts, and a trace has to be cut as well.
I didn't check the link, was the that a bulb solder sucker?
As Elfin said, if you add solder to all 16 pins and then get your iron in there and get that solder nice and melted all the way through the porthole.
once you pop it, it should slurp up that pretty good., afterwards you might want to take some needle nose and rotate each leg of the ram, because
there might still be some slight soldered surfaces.
The nice thing about a desoldering iron is you can rotate while you are pulling the trigger and it sucks all the solder out really well.
Makes the task, much less labourous. Witch if you decided to change all 16 chips… is quite a task indeed.
if you just change that one chip.. you will be ok for a few weeks or months… until the next one goes bad too.
then you will be doing this all over again. Hopefully by then you have not misplaced all your supplies.
If anyone is interested in a owning a pretty good all-in-one desoldering iron, There is a pretty decent one on ebay for like 100 bucks free shipping.
http://www.ebay.com/itm/S-993A-110V-90W-Electric-Vacuum-Desoldering-Pump-Solder-Sucker-Gun-/161413419282?pt=LH_DefaultDomain_0&hash=item2594fd5112
I own it and its pretty decent. I like my hakko fr-300 much better, but those are 3x more. If you can get a Hakko 808, They are the Beastliest of all of them…
i think. But even those have went up in price.
the hakko 808 with its V Twin Vacuum pumps on the end there. ITs like a mini Harley engine.
