Trash80toHP_Mini
NIGHT STALKER
. . . but the spec. is literally stuffed with goodies.
Bodged together EVERYTHING remotely IIsi related I could find and substituted kinda-sorta variety junk for what I couldn't lay my grubby little paws upon without tearing the place apart:
We'll start with the good news, it's got 1.37 sq.in. less surface area than the CorrugatedQuadra chassis in the pic:
Not so bad, it does fit on a sheet of letterhead!
I went ahead and pointed the business end of everything in the pile toward the camera to save film.
What a lump of junk, but it began to grow on me after a bit.
Doesn't get much better from this angle:
Gets even worse from this side:
Much, MUCH worse yet, but don't stop here, it gets better toward the end, I promise!
Flipped the pic over to show the potential I saw in it and right away saw that nobody else would see it. :-/
Nuts! No way to put it into words. So I skinned it over with laser cut plexi in the surrealistic world inside the bubble of my OS9 Graphic Arts mode reality exclusion zone.
Q700 influence is obvious, Multiple panel influence is the Apple Multiserver, but its six segmented panels would have been too much.
Fan in the pics is only 100mm. It'ss standing in for the huge one stored in a box somewhere around here, but most likely for the 120mm RGBY LED clear job I've been eying on eBay. Hacking those four LEDs to run off an HDD's disk access indication header will make it into one of my upcoming hacks one way or another. [}] ]'>
The IDE Zip is standing in for a 250MB IDE Zip drive. I've got a pair of them mounted to 5.25" brackets with big IDE->SCSI adapter boards underneath. They were made by vertical market upgrade mfr. for some non-Mac OS or other. They work great for moving files onto a Mac, but moving files off the Mac is problematic. Trying to eject the disk or to shut down the system hangs every Mac OS I've tried so far . . .
. . . perfect for a prototype! [] ]'>
Purple panels are bolted up to the black plexi chassis' front panel using some nylon spacer/standoffs and hex head cap screws. The four on the top left panel are just for show, that one's hot glued to the CD Tray. If I budget the greenbacks to actually have any of this cut it'll be fun, but I've got way too many hacks laying around as it is.
The thing is a BEAST, but with CD/FDD/5.25" Zip Kluge/HDD and monster cooling unit for it all requires a bit more cubic than the other builds going on around here lately.
The empty cubic between the stock IIsi PSU and CD is earmarked for the aux. lump-onna-rope power Molex driving doohicky for an IDE/SATA->USB adapter to power the Savvio, Zip and CD.
What looks like a Thin/ThickNet card is a Futura II VidCard with the ThinNet NIC Daughtercard inatalled. Maybe I'll finally break down and buy a transceiver for it. Like I said, I've thrown everything but the kitchen sink into this pile. So along with the Rainbow-Blinky-Lights Fan and the Transceiver, I'll be looking for a Barbie sized Laundry Basin for the backside to fill the cubic left over after the DC adapter is installed.
All in all, it's only 90% the volume of a IIsi and only 70% of the Quadra 700's volume! It takes up only a 7" wide x 8.5" deep patch of desktop, so that's considerably handier than either of the above and it has I/O up the wazoo.
Margarita time! [] ]'>
edit: oopsie! Fan opening winds up at the bottom portion of the side panel when you turn the business ends of the MoBo and PSU through 180 degrees to where they belong.
