LisaEm 1.0.0 has been Released
sunder
LisaEm 1.0.0 has been released. Download is available at http://lisaem.sunder.net/downloads.html
as usual.
Code:
Lisa Emulator Change History                         http://lisaem.sunder.net/
2007.07.06 - Display color balancing to remove fuzziness.
2007.07.05 - LisaConfig bugs found - overwriting date information with
            garbage on save of preferences.
          - corrected a bug preventing the grabbing of the host time and
            date.  Found that MacWorks locks up when date is invalid.
2007.07.04 - LisaEm documentation completion
2007.07.03 - Testing various opcodes to locate scroll bar arrow bug in LOS
            not found, but eliminated shift/rotate opcodes.
2007.07.01 - regression testing to locate MacWorks bug - not found yet, high
            probability that it lives somewhere inside the C++ code.
2007.06.30 - added Mac OS trap symbol printing for A-Line traps for tracelog
2007.06.29 - fixed inability to detect no-floppy from Lisa boot ROM
          - fixed entry to Service mode - not perfect, need to attempt
            to boot from bad profile.
          - fixed tracelog bugs (hardcoded /log/lisaem-output)
2007.06.26 - fixes to build.sh for differences between platforms.
2007.06.22 - floppy de-serialization routines.
2007.06.20 - rawbmp.h code finally works - except crashes on win32.
2007.06.13 - rawbmp.h code works, much, much faster!
2007.06.12 - wxImage::SetRGB works - faster than old blit code
2007.05.01 - integrating new wxui code is taking me too long becaue of a lack
            of free time, so I'm going to go the other way so as to be able
            to make a release soon.
2007.04.24 - Dual Parallel ROM cheat
2007.04.15 - Found OS X display slowdown issues
          - Fixed display sizing issues when skinless.
2007.04.14 - Fixed skins on/off switch on OS X
2007.04.13 - Debugging video system on OS X
2007.04.11 - Added Disk Copy 6.x detection to libdc42 open.  This allows
            better error messages to be returned.
2007.04.10 - Added MacBinII stripper to libdc42 auto_open
2007.04.09 - finalized buffered raw keycodes to compensate for repeats
          - decoupled the COPS 1/10th second timer from Lisa CPU and tied
            it to the host clock, clock is now acurate regardless of CPU
            speed.
2007.04.08 - added Unthrottled menu option for those who want to melt their
            host computer.
          - added buffered raw keycodes to compensate for repeats.
2007.04.07 - bug with raw keycodes that prevents updates found and fixed.
2007.04.06 - Changes for OS X issues (might roll these back since Jerome
            Vernet found that the slowdown issues go away with wxWidgets
            2.7.2, will test on all platforms before committing to either
            path.)
               - reworked display to draw directly to dc and skip full blit
                 only done for AntiAlias mode, need to redo for all others.
               - reworked timing loop to no longer need wxMilliSleep
[/code]
