QuadSix50
You forgot to include the wildcard at the end of "xorg.conf" that I included in the command above. This way, it will find anything that begins with "xorg.conf" in the name. The way you did it will only find exact matches.
I'm reviewing your xorg.conf file that you poster earlier to see if there's something wrong at that line.
I have a feeling that something might be awry in the way your have your formatting of the file. Are you copying the contents or retyping everything?
If you want, I can send you the file itself in the proper formatting. You would just have to move the file over to /etc/X11 yourself.
