No good. I tried each depth too. It just boots into 800x600, and is unable to be changed. :?:OK, progress!
You're missing the DefaultDepth 24 in the Section "Screen". Place it right on a line before SubSection "Display". Also, change Modes "2048x1536" to Modes "1024x768". Save the file and try again.
If it still doesn't work, change the DefaultDepth from 24 to 16 and move the Modes to the SubSection with the Depth of 16.
Section "ServerLayout"
Identifier "X.org Configured"
Screen "Screen0" 0 0
InputDevice "Mouse0" "CorePointer"
InputDevice "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
RgbPath "/usr/share/X11/rgb"
ModulePath "/usr/lib/xorg/modules"
FontPath "/usr/share/fonts/TTF"
FontPath "/usr/share/fonts/OTF"
FontPath "/usr/share/fonts/Type1"
FontPath "/usr/share/fonts/misc"
FontPath "/usr/share/fonts/75dpi/:unscaled"
EndSection
Section "Module"
Load "GLcore"
Load "xtrap"
Load "dbe"
Load "dri"
Load "extmod"
Load "record"
Load "glx"
Load "type1"
Load "freetype"
EndSection
Section "InputDevice"
Identifier "Keyboard0"
Driver "kbd"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/input/mice"
Option "ZAxisMapping" "4 5 6 7"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Monitor Vendor"
ModelName "Monitor Model"
EndSection
Section "Device"
### Available Driver options are:-
### Values: : integer, : float, : "True"/"False",
### : "String", : " Hz/kHz/MHz"
### [arg]: arg optional
#Option "NoAccel" # []
#Option "SWcursor" # []
#Option "Dac6Bit" # []
#Option "Dac8Bit" # []
#Option "DMAForXv" # []
#Option "ForcePCIMode" # []
#Option "CCEPIOMode" # []
#Option "CCENoSecurity" # []
#Option "CCEusecTimeout" #
#Option "AGPMode" #
#Option "AGPSize" #
#Option "RingSize" #
#Option "BufferSize" #
#Option "EnablePageFlip" # []
#Option "Display" #
#Option "PanelWidth" #
#Option "PanelHeight" #
#Option "ProgramFPRegs" # []
#Option "UseFBDev" # []
#Option "VideoKey" #
#Option "ShowCache" # []
#Option "VGAAccess" # []
Identifier "Card0"
Driver "ati"
VendorName "ATI Technologies Inc"
BoardName "Rage 128 RE/SG"
BusID "PCI:0:16:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Card0"
Monitor "Monitor0"
DefaultDepth 24
#Viewport 0 0
Depth 1
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
#Viewport 0 0
Depth 24
Modes "1024x768"
EndSubSection
EndSection
Nope.Do you still have any straggler xorg.conf or xorg.conf.new files in either the /root directory or your new user's home directory?
EndSection
Section "Files"
EndSection
Section "Module"
Load "GLcore"
Load "xtrap"
Load "dbe"
Load "dri"
Load "extmod"
Load "record"
Load "glx"
Load "type1"
Load "freetype"
EndSection
Driver "kbd"
EndSection
Identifier "Mouse0"
Driver "mouse"
EndSection
Section "Monitor"
EndSection
Section "Device"
#Option "AGPMode" #
#Option "AGPSize" #
#Option "Display" #
Identifier "Card0"
Driver "r128"
BusID "PCI:0:16:0"
EndSection
Section "Screen"
Device "Card0"
Monitor "Monitor0"
DefaultDepth 24
#Viewport 0 0
Depth 1
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
EndSubSection
#Viewport 0 0
Depth 24
Modes "1024x768"
EndSubSection
EndSection
EndSection
Section "Files"
EndSection
Section "Module"
Load "xtrap"
Load "dbe"
Load "extmod"
Load "record"
Load "glx"
Load "type1"
Load "freetype"
EndSection
Driver "kbd"
EndSection
Identifier "Mouse0"
Driver "mouse"
EndSection
Section "Monitor"
HorizSync 31.5 - 87 # <--This line is a sample! Check the horiz. sync for your monitor!
VertRefresh 40-90 # <--This line is a sample! Check the vert. refresh for your monitor!
EndSection
Section "Device"
#Option "AGPMode" #
#Option "AGPSize" #
#Option "Display" #
Identifier "Card0"
Driver "ati"
BusID "PCI:0:16:0"
EndSection
Section "Screen"
Device "Card0"
Monitor "Monitor0"
DefaultDepth 16
#Viewport 0 0
Depth 1
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
Modes "1024x768"
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
EndSection
Section "Files"
EndSection
Section "Module"
Load "xtrap"
Load "dbe"
Load "extmod"
Load "record"
Load "glx"
Load "type1"
Load "freetype"
EndSection
Driver "kbd"
EndSection
Identifier "Mouse0"
Driver "mouse"
EndSection
Section "Monitor"
HorizSync 30 - 95
VertRefresh 50-200
EndSection
Section "Device"
#Option "AGPMode" #
#Option "AGPSize" #
#Option "Display" #
Identifier "Card0"
Driver "ati"
BusID "PCI:0:16:0"
EndSection
Section "Screen"
Device "Card0"
Monitor "Monitor0"
DefaultDepth 16
#Viewport 0 0
Depth 1
EndSubSection
Viewport 0 0
Depth 4
EndSubSection
Viewport 0 0
Depth 8
EndSubSection
Viewport 0 0
Depth 15
EndSubSection
Viewport 0 0
Depth 16
Modes "1024x768"
EndSubSection
Viewport 0 0
Depth 24
EndSubSection
EndSection
cat /var/log/Xorg.0.log | grep xorg.conf*
(==) Using config file: "/etc/X11/xorg.conf"
