Learning Program Development (System 6, of course :P)
MrMacPlus
What do I need to start? I want to dabble in a little bit of C, might be good for me... :p
Preferably links, please, I hate having to hunt down individual bits of software. :)
regards,
tm512
EDIT: One thing that might be a good experiment would be a classic program that, when run in OS X, calls to some 68k trap and set the color depth. to 1-bit, o' course. :beige:
MrMacPlus
But you might not like the answer to "HasDepth()".
Bah. I'll force it. See my thread earlier... Apparently some games set the color depth back to 1-bit.
Anyway, maybe you can help me. Maybe it would be easiest in PASCAL, although it doesn't matter as I have no experience in either C or PASCAL.
I want a dialog box to popup with two buttons, one saying "I'm feeling B&W" and another saying "I'm feeling Colorful". a PhD shouldn't be required to figure out what I want those buttons to do. :)
MrMacPlus
Well this is nice! :D I have ThinkC 5.0 downloaded. Time to try and get started tomorrow. I believe school shall be cancelled again cause of snow. Any tips would be much appreciated, I haven't done C past command line apps. [^] Noob on board!
EDIT: ThinkC runs fine in vMac and has sample code. :D
dav7
Hm, if I wanted to do some development too, where could I find ThinkC? Or is MPW sufficient (ie, does it include a compiler)?
-dav7
Dog Cow
-dav7
Check on Apple's web site. All their old development tools, pages, and downloads are still there.
II2II
The basic problem with MPW, at least the version from Apple's site, is that it requires 7.5 (or maybe 7.1 with some extensions). This makes it somewhat more difficult to test applications for System 6 because you essentially have to use it as a cross compiler. As such, something like THINK C or THINK Pascal are probably better options.
porter
Alas, I've tried compiling on one system and running the result on System 6 without success.
MrMacPlus
Okay, thanks. I can't find ANY reference to setDepth in Think Reference.
MrMacPlus
Tengo una problema...
My little app is supposed to restart the computer with the Restart(); trap. I get
Code:
undefined: Restart();
porter
Code:
As a suggestion, it's a really, really, really bad idea to have some random application restarting the operating system, unless of course you are writing a program for Microsoft Windows.
MrMacPlus
Code:
I could always port it. :p
Anyway, this also happened when I tried using setDepth.
MrMacPlus
I just had to add MacTraps to my projecct and it linked, and ran...
Now it's time to find out how to use setDepth.
