LC 475, CD-ROM and a new System 7
Hey Army men,
I have a LC 475 and an external SCSI CD-ROM. I need to install a system 7.5.3 from an Apple site. My second computer is a MacBook Pro. Any tips how to burn a CD with 7.5.3 under MB Pro and then... will my LC 475 read it properly?
PowerPup
I did this once for my Classic II. Though my second Mac was a PowerMac 6100. I used AppleTalk and copied all the disk images to my Classic II, then booted up from a startup disk. (I think it was the 7.6 Startup disk.) And ran the 7.5.3 installer from the Hard Drive. :D
The question is how to get them to the LC475.... :-/ If your LC475 has an ethernet card then you could transfer the files through FTP.
Oh! I know! Do you have a PC anywhere!? (Shocking I know. :p ) You could use TransMac, a program for Windows that lets you read and write HFS/HFS+ images. (15 day trial, long enough for this. :) ) You could get all the images onto a PC, run TransMac and burn them on a CD using the HFS format. Then pop the CD in your SCSI CD drive and TA-DA! :D
Yes, It has an ethernet card. Could you give me some tips on - how to do that?
Splendid idea! I will give it a try and let you know.
