You are going to need to call things by their proper names. And put the toner in the right compartment. Get the service manual!
What you might actually have, reading between the lines, however, is a blockage in the paper feed pathway - and it's very, very hard to get this out if it is deep in the bowels of the machine without disassembly. Honestly. It happened to me only a month or so ago, and it took me a good couple of hours to diagnose and to fix. It's also not the first time it has happened, as the old machines are prone to paper feed errors now that their paper rollers are old and withered. You end up yanking the misfed paper out and tearing it, leaving blockages in the machine.
My LW630 Pro is my main home printer and it works wonderfully well, but it has certain quirks. On the basis of my experience: (a) You will find that stripping down, cleaning, and ensuring that there are no small bits of paper torn off and blocking the paper feed can work wonders. ( B) I would say that a printer from 1993 now needs a good seeing to in this respect, complete with lubrication of moving parts, attention to the drive belt, a vacuuming out, and so on. © There is absolutely no substitute for a working toner cartridge. (d) The LW Pro also typically needs attention paid to its rubber rollers, both in the top of the unit, in the middle, and below just above the paper tray (where there is a sort of arm that picks up the individual sheets of paper) before it will work well after all these years. I would get and apply some rubber renue to the rollers while I had it apart.
Note that, once it's working (hopefully!), there is also an Apple Laserwriter Utility (or is it Printer Utility? - I forget) which you can use to make some software adjustments to the machine. These are much more sophisticated units than a Stylewriter, having, for instance, onboard 68030 and 68882 processors.
