lagomorphonic
I figured I'd post this as a last ditch attempt before it went into the landfill/ewaste. I've got a LaserWriter Pro that I got from someone along with an LC III. Both had been in storage and were very well looked after machines, but just not used in ages. The LC III works, but unfortunately the LaserWriter doesn't even power on as far as I can tell. When I connect it to power (not connected to a computer at all, just mains power) and flip the switch, none of the lights come on and there's no sound or noise from the unit at all. If I connect it to the LC III it's the same issue, however, connecting it will cause the LC III to freeze. Is this something as simple as a fuse or internal breaker or something simple internal to the LaserWriter? Or is it dead? Or is it even worth bothering with? I couldn't find any posts or anything online regarding this issue.
