Quadraman
It's slow as crap as far as G4's go. There are G3's for the 6100 with a faster clock speed, so if you don't need Altivec, the fastest G3 upgrades are better.A G4 in a Nubus PowerMac? That's surely insane!
Yes it can }The 6100 cannot accept a full-length NuBus card.
For the prices of beige machines these days, if you want a system 7 machine, then a PCI Powermac will be much better than a 6100. A 7x00 machine will run 7-9 and be a lot faster and more expandable and can run OS X. A 6100 can't.If I wanted to run PowerPC System 7, I'd totally consider a 6100 to be in the running.
Although given the availability of G3s these days, you wouldn't really get any pre-G3 machine for OS X, given that it will most likely be very slow (except perhaps on some of the last ones eg 9600) and you can only go up to Jaguar anyway. The only reason I would install OS X on one, if I had one, would be that it would be interesting getting it to work and seeing it run! For actually usingA 7x00 machine will run 7-9 and be a lot faster and more expandable and can run OS X. A 6100 can't.
Agreed, the 6100 does have a nice case design, and can be fitted somewhere where one of the later PPCs probably wouldn't fit. Though it looks ugly with yellowing and without the CD bezel, which contributes to my feeling of rubbishness!in an adorable VCR-shaped case.
I suppose in another 7 years time I'll be having the G3 to G5/Intel transition crisis that some of you seem to be having now...I had the exact same 6100->G3 transition crisis you're having now, about 7 years ago.
My 7500 is running Tiger.Although given the availability of G3s these days, you wouldn't really get any pre-G3 machine for OS X, given that it will most likely be very slow (except perhaps on some of the last ones eg 9600) and you can only go up to Jaguar anyway.
I don't think there is anything at all in there at the moment, no adapter or anything like that. It may have had a card installed at some point though, as there is a gap on the back where the card would come out, which would presumably be covered up otherwise. It does have the wrong top cover (says 66 when it's a 60), so I suppose it could have been an AV or DOS machine and since lost its card, there's no way of knowing. Thanks for the offer, but even if I did have an adapter I doubt it would be worth the cost of shipping the card over here, given that it would still be slow and ugly (no bezel) :'(Check inside your 6100 to see if you have the PDS 90-degree adapter already. If you do have the adapter, or can get one elsewhere, I have a couple of the AV cards lying about, I'd be happy to part with one for $5 plus shipping?
Just out of interest, when did the in-built display output get any good (ie capable of producing something useable like 1024x768 and more than 256-colour, or even 800x600 with more than 256-colour)? Did the first PCI machines have it or did it take a while for this to appear? Are the first PCI machines also noticeably faster than the Nubus PPCs, or do you again have to go quite a way forward to get decent performance? Not that I'm thinking of looking for one or anything, I'm just curious as I don't have any experience of anything between the 6100 and the G3.I have to agree though, a PCI-based beige PowerMac gives a better user experience.
I could probably agree with that for the most part, but for the record, the 6500/5500 used the same ATI Rage II/IIc/II+ video that the rev A G3s used. It's pretty slick. The only drawback is the 2 MB VRAM limitation on those models.I don't think the onboard video on any beige was ever that great, except for the G3. Anyone who is serious about using a beige PCI Powermac eventually puts a video card in one of the slots.
Well, the G3 upgrade cards also act as AV card adapters...I don't think there is anything at all in there at the moment, no adapter or anything like that.Check inside your 6100 to see if you have the PDS 90-degree adapter already. If you do have the adapter, or can get one elsewhere, I have a couple of the AV cards lying about, I'd be happy to part with one for $5 plus shipping?
