I've just got an SE/30 and need some help
dochilli
You need a local talk bridge. That can be one of ASANTE (Asante talk or Asante print) or for example a SE/30 with an Ethernet adapter and the local talk bridge software.
Here you can get more information:
https://lowendmac.com/network/bridge.shtml
Sometimes you need an old ethenet hub with 10mbit. The old macs do not work with 100mbit.
You'd need a Mac with an ethernet interface running 7.5 to act as a bridge. I used an SE/30.
Doesn't need to be 7.5, AFAIK anything 7.0+ will work, and the control panel is free.  I had it on an LC II running 7.1 until I migrated to Apple Internet Router.
Stephen_Usher
They will work with any switch, but only at 10Mbit. It merely depends upon how brain dead your network switch is. If it's a decent one then without being able to negotiate the connection it should default to 10Mbit, which is what the old 10BaseT hubs ran at.
I had my SE/30 connected to a gigabit switch with no issues.
Bendix
Thanks for the many answers! I found this with some pics of the hardware in it:
http://retroapplecomputing.com/lt-eth-bridge.php
I did not really understand, why the powerbook was needed as an intermediate node in this example.
I have two SE/30s, one with a working Asante Ethernet Card. So with the Asante local talk bridge and the local talk phone net adapter I should be able to connect my 2nd SE/30 to the net like Stephen_Usher mentioned?
Bendix
Cool! So can I use a serial printer cable to connect the two SE/30s and then install the local talk bridge extension on the ethernet mac and everything will be fine? What about TCP/IP on the mac without the ethernet, how will I get internet connection?
