I've recently acquired a classic Mac SE/30 (and a SCSI CD drive which I can't get working at the moment). I've put a new battery in it and fixed the floppy drive, and given it a clean. The problem now is that I can't actually get any software on it.
Everything I have downloaded on my PC is either a .img, .bin, .image, .hqx, or .sit. and they won't run after I copy them to the Mac.
Nothing I've downloaded will install or uncompress without Stuffit or Disk Copy. I can't get Stuffit on, as I need Stuffit to put it on.
I can't find any install program I can put on a floppy and just run on the Mac. It's driving me mad.
I found a broken link to something called macdisk.exe which should make a mac disk with stuffit on to install. After finding the archived version of the site I got that, then had to get an old Win 98 PC to run it on, which then failed to run it.
I tried installing StuffIt on my PC, but that gave me internal errors with all the .sit files.
I even have a modern-ish Mac with OS X (10.8.5), but after copying the file to the PC floppy, then transferring it to the other Mac (with file exchange) it wouldn't run. It said something about it not having the software it was made with. So I formatted the HD Floppy on the SE, then put it in the modern Mac, then it wouldn't copy the file to it (read only)! Arghh!
I tried the CD drive, which had the cable plugged into the bottom port and nothing in the top. It didn't work, so I found a SCSI terminator and put that in the top. Nothing. I swapped the ports, and still nothing. I get a power light, and it ejects, but nothing happens when I put an audio disc in it. I haven't put in a data disc, as I assumed something should happen with any disc. It's an AppleCD 300e Plus with SCSI ID 3. I was hoping to use that to transfer files to the Mac.
If anyone can help, it would be amazing, as I have this great classic Mac (June 1991 running System 7.1) and can't get anything on it.
Things I have available are: Win 7 PC, Win 98 PC, Mac OS X, Amiga 500 & 1200 (the 1200 has a Mac emulator on a separate partition, though I can't remember how to run it, but could try if that was going to help). I also have a SCSI Zip Drive that I used on my Amiga, but haven't got any spare disks for that that I can Mac format, and I'm wary about using it in case I get the click of death, as it hasn't been switched on for about 20 years. I have my Amiga SCSI CD drive, too, so that might be an option, though I'd rather leave that and use the Apple one if I can.
