I love MO!
Another cool feature of 3.5” is the labels are the same as floppy disk labels, so you can print custom labels for them like these.
View attachment 64595View attachment 64596View attachment 64597
The 5.25” format is kind of “weird”. The disks are double-sided like old records or cassette tapes. So you have to flip to access the other half of the reported capacity of the disk. So 9.1GB is actually 4.5GB allowed per side.
The 3.5” is definitely a cooler format though. Availability of SCSI, USB (native), ATAPI, and Firewire drives makes them very universal.
Add to that, even the highest capacity 2.3GB drive can read AND write to the lowest capacity media, 128MB.
I don’t know if it’s something to do with the sector size or just the process I used, but it’s fairly easy to image a CD image over to a MO disk and use it just like a CD. This includes bootable disks. I was able to make a bootable A/UX install MO disk.
If you get into 5.25” be aware that not all disks and drives are compatible.
Check out this post:
https://68kmla.org/bb/index.php?threads/using-magneto-optical-drives-on-vintage-68k-macs.38010/
