Jinnai
I've had a horrible time trying to get disk images from the internet to my Apple IIe. What I do is download the .dsk, .po, or .do file, boot my IIgs into ADTPro from 5.25" FDD, transfer it via serial to the IIgs and have ADTPro write the image, and then attempt to run it.
Some games will run on the IIgs but not the IIe, but in most cases it appears to be cracked software or software that displays a code error like this:
That's not so bad. But a multitude of written disks show "Error #8", like this:
And when one does that, it does the same thing on both the IIe and the IIgs. I've tried three different drives, numerous different disk, cleaned the drives, and reseated the chips on the IIe floppy drive board. And I've run the images in an emulator without any issue, so they're not corrupted. What is up with that?
Are there simply a lot of images on the internet that work in emulators, but ADTPro can't properly make a bootable disk from?
![Cz0OBJr.jpg.52f0343f8daab956f7d268da1d7340a3.jpg](https://68kmla.org/forums/uploads/imageproxy/Cz0OBJr.jpg.52f0343f8daab956f7d268da1d7340a3.jpg)
![5NTpvps.jpg.4a49a726e96083725da7b81f0ac38171.jpg](https://68kmla.org/forums/uploads/imageproxy/5NTpvps.jpg.4a49a726e96083725da7b81f0ac38171.jpg)
