Is this a decent price?
mac2geezer
Local Craigslist has a 20 inch G5 iMac, 1.8 MHz, 2GB, 150 GB HD, OS 10.4.11, CS3 Suite, keyboard, mouse, original install disks. All for $600. Is that a decent price?
4seasonphoto
Don't touch G5 iMacs, too many problems. If you really want a G5, buy a Power Mac. So far, no problems with the Intel iMacs.
4seasonphoto
Got a number of G5 towers at the office, some of which have been running continuously for years. Not a single problem.
The PowerMac G5s are doomed to coolant system failure (leaking coolant). :-(
... only the ones that use coolant fluid. Most of them don't. My G5 has almost 5 years strong and the only failure so far was a weird brown pillow shaped capacitor in the power supply.
My mom has a used iMac G5 that runs fine. I think for any reasonably well used iMac G5s that capacitor plague would have been exposed by this point in time. Not all of them had the bad capacitors and sometimes Apple will still fix the problem for free if you bother them enough.
joshc
... It doesn't even come with a Floppy Disc Burner!!!
I think that's going to become an Internet phenomenon, isn't it? :p Anyway, $600 for an iMac G5 is not a good deal.
mac2geezer
Thanks for all the replies. The same Craigslist had a MDD (2003) DP 1.25 for $350, which I think is a little high, but haven't done an eBay comparison.
Christopher
As cool as MDD's are I think thats rather steep seeing as how the G4 is the new G3 in today's world.
G5's at most should be $450 imo.
thinkdifferent
I would suggest a dual core processor. Besides, 1.8 MHz really isn't very fast ;)
