drybones99
When I tried using the .dc42 profile image that I had working with LisaEm 1.2.6 with the new beta version, I got the ipc error again. Furthermore, when I attempted to create a new profile image by installing LOS 3.1 by booting from the first install floppy image, I get "The Tag checksum failed for this disk. It may be corrupted." This is followed by the same ipc error as before and an endless loop of the disk drive sound. The floppy images are in .image format, but they were working just fine in LisaEm 1.2.6, although I get the Tag checksum error there as well, but afterwards, it boots properly instead of giving me the ipc error. I suspect that the disk image may not be the problem here, seeing as I have been unable to get the virtual Lisa 2 to turn on in any manner with the beta LisaEm. If you need a BLU Widget image, I have already uploaded one at the start of this thread, but I'll attach it again to this post. Ignore the long string of numbers in the extension, for this is an artifact of uploading it on this website. The original file has no extension. I have also attached the LOS 3.1 Disk 1 that boots fine in LisaEm 1.2.6, but fails in the new beta version.
View attachment __-_BUILT-IN_PARALLEL_PORT_(10_MB_Widget_Hard_Disk).15240174b867249d873369e340911b47
View attachment LOS 3.1 1.image
