Is a Performa 6400/180 motherboard compatible in a 5500/250?
Gil
Yes. The 54xx/55xx boards and their 6xxxx counterparts are interchangeable.
JRL
YES! *does a backflip*
Thanks so much! Are you sure it'll be compatible with the extra PCI slot and all?
Gil
Well no...You'd have to swap the PCI risers. The 5500 case can only accommodate 1 PCI slot.
JRL
BTW, can I use my old 5500 plastic cover, or do I need to track down a 6xxx series plastic cover?
Gil
Whatever board you're putting into the 5500, you'll need the 5500 cover.
