Timtheloon
Hello All,
I am looking for some assistance with my Powermac 5500/275 I bought this with a faulty motherboard which had bad battery damage which had killed the capacitor pads near it I came across a 6500/250 mobo which from what i can see is exactly the same mobo with he exception of the 25mhz.
however when I try and power up the 6500 with the 5500 All in one chassis it gives the Apple Chime and then it just stays on the grey/whitish screen with the mouse cursor which will move around when moving the mouse but it never gets any further. it does allow me to do a PRAM reset but after it just returns to that screen
Has anyone experienced this before, is it because the 6500 is not compatible with the 5500 all in one chassis? just to add, the All in one chassis works fine with an 5400 mobo.
let me know you thoughts and expertise on this.
Update: I've also tried removing the hard drive to see if that helps, no change
