Index of CAD Models
Scott Squires
This thread is a directory of 3d models that you can buy or print yourself.
For the latest, most accurate and inclusive listing, go to the bottom of the thread. The intermediate posts are old and useless. The latest update is always at the bottom.
Thread Etiquette
  • Do post projects that aren't in the list, updates, and corrections (check the latest list first). A thread maintainer will add the info and make a new post.
  • Don't discuss the projects here. Go to their respective threads.
Scott Squires
Changes
  • Updated links for new forum
Apple IIgs Compact SE/30 Macintosh II series
  • Macintosh II Reset / Interrupt Switch - by ktkm - post
Quadra 800 / 840av / PowerMac 8100 / 8500 / 9500 Quadra 900 series
  • Quadra 900 series side cover latch - by ktkm - post
Macintosh Portable PowerBook 100 series PowerBook 500 series Miscellaneous Machines
  • Slim optical drive adapter (iMac G3 / PowerBook G4 / G4 Cube) - by deBaer - thread pending restoration - thingiverse
  • Comm Slot Cover - by Merk - post
SCSI Tools
jessenator
Thanks for the add! I'll also include
Quadra 700
  • Vertical foot updated: Thingiverse (which is honestly most suitable as arubber/silicone cast molding positive)
  • Vertical foot remix: Thingiverse (which is more suited to being a pop-in replacement) by ActionRetro
Scott Squires
Changes
  • ActionRetro: add Quadra 700 Vertical Foot (FDM snap-on)
  • jessenator: add Quadra 700 Vertical Foot (rubber/silicone cast molding positive)
Quadra 700 Quadra 800 / 840av / PowerMac 8100 / 8500 / 9500 Quadra 900 series
SCSI Tools
Scott Squires
Changes
  • PotatoFi: add RaSCSI Mini, Slim, and Pro Cases
Apple IIgs
Compact
SE/30
Macintosh II series
Quadra 700
Quadra 900 series
Macintosh Portable
SCSI
Tools
Scott Squires
Changes
  • 360alaska: add Portable foot
  • 360alaska: add Outrigger Clip
  • 360alaska: add 8100 Speaker Holder
  • 360alaska: add Mystic Plate
  • Westinghouse: add Powerbook 1xx battery tray
  • galgot: add Wallstreet Hinge
  • avadondargon: add SE Interrupt / Reset Switch
  • BlueBoy: add SE HDD Faceplate
  • redruM69: add Portable Foot
  • Swolfington: add ADB Mouse II ball cover
  • Swolfington: update 800/8100/8500/9500 Drive Bay Bezel - Floppy
  • Swolfington: add 800/8100/8500/9500 Drive Bay Bezel - Blank
  • Swolfington: add 800/8100/8500/9500 Drive Bay Bezel - CD-ROM
  • Swolfington: add 800/8100/8500/9500 Drive Bay Bezel - Jazz
  • Sunoo: add Performa 6200 IDE to SD Drive Sled
  • redruM69: add Portable SCSI2SD v5b bracket
  • Swolfington: add 800/8500/9500 Drive Sled
  • Swolfington: add Q700 Interrupt/Reset Switch
  • joethezombie: add Macintosh II Vertical Stands
  • SDUBjed: add Plus Battery Door
  • 360alaska: add Q950 Open Bezel
  • 360alaska: add Q950 Caddy Bezel
  • jessenator: add Outrigger Foot
  • jessenator: add Trim Pot Adjustment Tips
  • olePigeon: add LaserWriter / Plus paper cassette stopper plate
  • jessenator: add Color Classic Badge
  • 360alaska: add Portable Battery
  • Opti: add Portable IDE to mSATA bracket
  • sutekh: add PowerBook 1xx Li-Ion Battery Pack
  • MindWalker: add IIci / IIcx Case Feet
  • MindWalker: add IIci / IIcx Interrupt/Reset Switch
  • warmech: add Q800 Floppy Drive Sled
Apple IIgs Compact SE Series SE/30 Color Classic Macintosh II series LC / Performa 5xx Quadra 630 / PowerMac 6200/6300 Quadra 700 Quadra 800 / 840av / PowerMac 8100 / 8500 / 9500 Quadra 900 series Macintosh Portable PowerBook 100 series PowerBook 500 series PowerMac 7200/7300/7500/7600/G3 (Outrigger) PowerMac 8100 PowerBook G3 Miscellaneous Machines
ADB SCSI Printers
  • LaserWriter / Plus paper cassette stopper plate - by olePigeon - post
Tools
Fizzbinn
Here's another one:
PowerBook 500 ram clip:
Thanks to @aladds
Daniël
Assortment of commonly broken Quadra 610/660AV/Power Macintosh 6100 et al. parts by Thingiverse user amirite. A blank bezel, custom ZIP drive bezel, power button, and foot:
redphantom
I'd like to take a moment to add in a project I remixed. I did a CD Bezel for a Power Macintosh 6100. It was originally based on this design:
This one has been remixed by me to include a larger opening for the CD Tray, repositioning of the hole for the manual eject, and an eject button. Remixes are of course welcomed:
